M105a2 trailer used 9.00x20 tube type NDT tires, air over hydraulic brakes and a very heavy front landing gear leg.What is the difference between a m105a2 and a m105a3? Is there any difference?
Clinto, the M105a3 was designed to be towed behind either the 2 1/2 or 5 ton truck.What was the intended truck for the A3 to be used with?
I'd like to know this also, been searching and can't seem to find the answer.Hmm....... could the landing gear from the A2 be adapted to the A3?
As for using A2 landing gear on an A3, anything is adaptable with enough time and money. Just remember that the A3 has a surge brake coupler mounted where the A2 gear mounted, so it will have to be mounted further to the rear.I'd like to know this also, been searching and can't seem to find the answer.
Also, will the wheels from the A2 fit on the hubs of the A3?
LC
