Differences in clutches, gasser and multi
oddnor
Drammen, Norway
Hi
My first replay after a freezing cold winter
I mean you can use the clutch , because the gear box can be used on both engines visa /versa
gringeltaube
Staff Member
2,695
Montevideo/Uruguay
Nope! Gasser plate for 12" disk has a bolt pattern of 6 (paired @ 3.5" distance) on 13.5" while the stock MF clutch (13" disk) has 4 pair, also spaced 3.5", but on a 14.5" bolt circle.
Not saying it can't be fit: friction surface of the flat gasser flywheel is 15"net so it could be redrilled to accept the MF pressure plate. Also, mounting height of both plates is more or less the same and depht measured from FW surface to transm. mounting surface is the same for both engines: 60mm, adapter ring included.
Not clear what the goal is, though. A sound 12"clutch should be sufficient for the gasser IMO...(!?)
G.
