Monster Man
- 1
- 0
Well, I ran into a slight roadblock in my airshift swap. I got the output cover off, and without even unbolting the transfer case itself. BUT, it turns out you need more than just the output cover. INside the sprag case there is a set of gears, in the air case there are two clutches. I got the one clutch when I purchased the case cover, but I didn't get the other clutch I need. Probably should have reviewed the manual closer before I started, but I was assured I had absolutely EVERYTHING I needed.
Now my question concerns the poor drawings in the TM:
it says to just pull out the gear assembly (5), or just pull off the clutch(3 in picture 1) when you undo the set screw. This indicates to me that the two assemblies are external, meaning a shaft protrudes from the t-case itself on which these two mount. Well, I got my output cover off and along with it came the gear assembly, and a shaft, leaving a female hole in the case.
Now, on the air case, is there a shaft connected to the clutch shown? If not I'm screwed, as I don't see any way to get my shaft departed from the gear assembly. Am I missing something? Hopefully anybody who's seen the innards of both cases can give me the specifics.
and also, it appears I will just need to remove the gear (4), and put the plate back on with no gear for it to match the airshift, or is that a different part in the airshift case where the gear is in the sprag case?
Thanks!
![](http://www.buschandbusch.com/tcase1.jpg)
![](http://www.buschandbusch.com/tcase2.jpg)
Thanks!
