Different starters??
builderboy
Emporia Ks.
Ok I have a 923a with 250 cummins. I believe the starter is bad. In one of my trips to salina I decided to pull a extra starter to have a spare. Thank goodness.
Both starters are a prestolite Mil-S3785
Here is my question. It appears as though they are the same starter, but yet they are different. It looks like the solonied is about 90 degrees different and the wiring is " flipped" The ground and battery wires are easy to identify. It's the small wire that came off the old one that I'm not sure where to hook it up.
Old starter- there was a wire was connected to the spade terminal on the "right" . the left spade terminal had a wire that went to the ground
New starter has two smaller studs the one on the left is labeled "new switch" with the letter 1 beside it and the stud on the right is labeled with a number four.
I just don't want to hook something up backwards here.
I also have pictures but have now spend thirty minutes and can't get them to load.
M35A2-AZ
390
Tonopah, AZ
You can take the noise part of the starter loses and turn it to match the old starter.
When I got my M923A1 the starter was bad and when I got the replacement I had to rotate the noise on the new one.[thumbzup]
builderboy
Emporia Ks.
I think the nose piece is in the correct place it's the difference between the two studs on the newer starter.
Does anyone have any ideas??
thanks
builderboy
Emporia Ks.
it's not the nose cone folks. old starter has two terminals. new starter has two studs. Not in the same place on each starter. Has anyone seen anything like this before??
Repeat. It's not the nose cone.
builderboy
Emporia Ks.
got it running !!! Is everyone else but me aware there are more than one style of solenoid on the starters? Heck there is even more than one style of starter!
Dmaxcc6spd
KY
Help! I need a couple of pictures! How many bolts hold the starter on? I can easily see one, but is there another hiding out of view?
Dmaxcc6spd
KY
I saw the Prestolite number at the beginning of the post. NAPA was unable to cross it to anything. Does anyone have some other part numbers for a starter for an 83 M925?
