RedneckRanger
- 0
- 0
- Nowhere/Missouri
M1009 Disconnected Fuse Box Wire - ???
84 M1009
Sat for last 7 years, largely in pieces. I've spent over a year (life happened and time is a premium) after I bought it putting it back together, cleaning endless connections, troubleshooting, replacing parts, lurking on the forums, reading the TMs and endless threads, etc. Most things I have learned about, and problems resolved, by searching and reading the forums and posts by other owners. I finally got the engine started a few days ago. Amazingly, after replacing the fuel pump and every fuel line, it unexpectedly fired up after only bleeding air from the fuel filter. I did not even have to crack a single injector line.
I am now chasing down remaining frustrating electrical gremlins.
Caveat: I try not to ever post questions. I am NOT terribly literate when it comes to reading and understanding wiring diagrams or electrical systems, and I do not presently have electrical test equipment, so please be patient with me.
Mechanical / Electrical Status: New batteries; new belts; repaired fusible links and burnt wires; fuse box taken apart and cleaned; alternators being rebuilt now (were both bench-tested as bad); doghead relay mod done; new relays throughout; new heater motor, resistor, and blower switch; new glow plugs, relay, and card; cleaned sockets, all grounds, and replaced all bulbs.
Problem 1 - Gen 1 light on (Gen 2 light never comes on) and Gen1 / heater fuse blows (and melts) the second you turn the blower on. I've checked and/or replaced everything related to the heater, and can't find any shorts, so I am hoping this one will be resolved with completed alt rebuilds. If you think otherwise, please advise. I just lost my wait light right before taking alts off (new bulb, but quit lighting, and truck still starts).
Problem 2 - I pulled apart my fuse box, yet again, to cut out the flasher diode. Flasher was replaced with new, but hazards stay on solid, even without using hazard switch. Researching similar posts pointed to the flasher diode and advised cutting it out.
In the process of pulling the fuse box apart to get to it, I discovered this non-connected black wire with white stripe inside the fuse box (shown below in pic). I cannot identify where it should be connected. I see no obvious location where it should be connected, and can't identify what it goes to.
Closest mention I found is a post that referenced: "small black wire w/white stripe - ground for STE/ICE diagnostic system"
Is that what this non-connected fuse box wire is? If so, what should I do with it / where should it be connected?
Thank you in advance for any assistance... And Merry Christmas everyone!
84 M1009
