- 3,196
- 3,168
- 113
- NORTH (Canada)
By chance, I found myself watching this episode and was on the verge of tears!
Breaking Point
These guys obtained a pristine up-armored M54 with a massive protective cage and first tested what the thing was capable of. That was the fun part. It cut a swath through the forest, snapping and pushing under trees that were over 19 inches thick, like matchsticks. The front of the truck was protected by the cage and the axle housings and underbelly protected by steel plate and the cage was designed to take the impact and bend the trees over. They hardly managed to scratch the paint on the cage - and they sure tried hard!
They shot lumber at the front of the truck behind the cage with a cannon; no damage; the front of the rad was armored and literally ripped the wood apart.
I am not sure what the engine was; they showed it only briefly, but the turbo was sitting up high on the passenger side, level with the top of the engine and the pipes crossed over the engine. I was thinking, maybe a turboed 250 Cummins conversion.
Then these idiots attempted to destroy the truck. They finally succeeded by subjecting it to a burnover (4 minutes of complete immersion in fire) and were left with a burnt out hulk. You can see the result on the link above; it is the cage sitting in smoke.
Anyway...the end of a quite incredible 5ton conversion.
Breaking Point
