distributor firing order
usmc81301
Bayfield CO
As long as the firing order is correct does it matter which plug the wire from the distributor goes to? Also, is there an easy way to test the starter solenoid switch? The starter?
Jones
Sacramento, California
First of all, what are you working on?
It makes life easier if the plug wires in the cap go to the correct plugs. Otherwise, come tune-up time, you'll never get the timing marks to line up.
Jones
If I recall from my Jeep days; the distributor shares the shaft that drives the oil pump and I seem to think that the slot is offset to prevent the distributor from being installed 180 degrees out. If I'm right so far then it wouldn't run at all if the plug wires weren't on the correct plugs.
Starter not cranking problems-- assuming you've got voltage to everything that needs it;
If you can get to the back side of the starter switch then bridging the terminals should make it crank over. If it does then any starter inop problems may be that switch. Next, if jumpering the starter solenoid spins the engine then check out the solenoid. If jumpering the solenoid does not help then the starter motor may need to be rebuilt or, if you're lucky, just a set of brushes.
Beacher425
Spartanburg, SC
The M38a1 starter is foot plunger operated. the floorboard foot plunger pushes a lever on the starter motor assembly. This lever does 2 things; it pushes the toothed portion of the starter shaft into the bell housing to engage the teeth of the flywheel assembly to turn the engine, and it depresses a plunger on the starter motor switch to turn the starter. I don't think that jumping the starter switch will do anything but spin the starter. A stock M38a1 does not have a starter solenoid.
Highly recommend the manuals for setting timing, and for anything else for that matter. They are free to download from willysmjeeps.com or you can buy a set which will have easier to see pictures.
