DIY Cab Corner Repair
MarcusOReallyus
816
Virginia
I took the bed off by myself but be careful!!! I used a come-along secured to the trusses of my shop. I used rope anchored to each corner of the bed. All you have to do is take your tail lights completely out and pull the wires through the bed. Then disconnect the fuel filler neck from the bed. Take the vent line loose from the rear end if it's attached to the underside of the bed. Next take out the 8 carriage bolts that hold the bed to the frame and your ready to lift it off.
