Do batteries affect injector pump/ fuel delivery to engine ??
kcbbqguru
kansas city
My truck was running fine at idle but when I got on the road it would start to act like it was out fuel (3/4 in tank) checked batteries they were shot, put 2 brand new ones in and truck seems to be running fine now??
thanks
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Could have been causing a power surge to the fuel solenoid on the IP. or not the full amount of voltage to open it all the way.
Guyfang
23,483
Burgkunstadt, Germany
What's the rated voltage for the fuel solinoid? If it's like most, it's 12-24 volts. If the charging system is not in order, and the batteries go below the rated operating voltage, then yes, you are going to have problems like you described.
