Do I have a "D" turbo or a "C" turbo?
houdel
9
36
Chase, MI
My truck data plate states my engine is a LDT465-1D. I assume that means I have a "D" turbo. However, it does have a very noticeable whistle. (Don't mind the slight oil drip in the engine plate photo, I power washed it after taking the picture).
Over the weekend, someone posted a photo of a "D" turbo and the exhaust section looked a lot fatter than mine (I think the thread got lost in the server crash). I've attached some photos of my turbo. Can anyone tell from the photos if it is a "C" or "D" turbo? The last pic is some numbers cast into the intake side, I had hoped it would be a part number but instead is a date (8/22/83).
houdel
9
36
Chase, MI
I just LOVE that turbo whistle! if you look real closely at my exhaust stack in the first picture of my posting http://www.steelsoldiers.com/index.php?name=PNphpBB2&file=viewtopic&t=6546, you can see a slight discoloration of the stack and three barely noticeable fasteners just above the joint between the J pipe and exhaust stack.
I have an internal race car collector insert mounted within the stack to tame the exhaust stack noise (without much reduction in the turbo whistle). I'm figuiring it gives me a 5-7 dBa noise reduction from the stack. Once I get some instrumention installed (EGT, Boost Pressure and back pressure gauuges) I'll list another post wih some hard numbers.
I'd like to reduce the exhaust noise 10-20 dBa, but I need to get the instrumention installed to make sure I'm not screwing my performance! Keep tuned for more data with hard numbers to see what I get. If the insert doesn't get me to where I want to be, next step is an Edelbrock 4" ID x 9" OD chambered high performance muffler. Gotta get that exhaust down to about 80 dBA, then work on cabin insulation to reduce the background mechanical noise for a reasonable quiet ride, I.E. be able to converse without shouting in the cab!
Lax
14
Upstate New York
Recovry4x4<
Thank you very much. Can you tell me anything about it? I was kind of hoping for a whistler when I bought the truck because I like the sound. No bid deal though. As long as it works forever I'm happy! Thanks again.
1,806
D turbos are regrded as being worthy of a tad more boost. The deeper throaty sound is preferred by many. Either will do you just fine and those who prefer the D tubo will tell you that the C sound can get irritating.
Lax
14
Upstate New York
Recovry4x4,
Thanks for all your help. Like I said, as long as it works every time the way it was designed to I'm happy. :wink:
Houdel,
Sorry for jumping in on your post. I hope it is okay. Thank you.
houdel
9
36
Chase, MI
Mike - Nothing to compare it to, there are no others in my area. Dave Allen is the closest, about 1-1/2 hours away, the one time I went to his shop he wasn't around. I assumed from the LDT465-1D on the engine plate that it was a "D" turbo (which is also what the mechanic at Selfrige ANG base, where I got it, told me). Glad it is a "C" turbo, I just LOVE that sound!
Djfreema
Santa Clarita, Ca
OK, I swapped my D turbo out yesterday for a C turbo but didnt do a test drive until just now and the butt dyno results are in. The D spools up quicker and gives the truck a better power band. There is a definate difference in power but nothing drastic. With my D turbo I was getting 15 lbs of boost earlier on, with the C, I am getting 13 lbs of boost and you really have to wind the motor out to get those numbers. With that said , I am still glad I did it since these things arent made for acceleration. When I had the turbos set side by side, I could see the C compressor wheel had a different design and I think I remember counting 1 less turbine blade on the C turbo. I already have my D sealed up for storage so I cant go back and count but I remember one had 12 blades and I think the other had 11 unless I miscounted.
dmetalmiki
2,027
London England
Just read all these comments..as I HAVE THREE spare turbos..2(two) HAVE clamps AND thinner "snails" AND DONT MAKE A SOUND!!! quiet as u like! THE one remailning one LOOKS EXACTLY THE SAME "small sails" CLAMP...whistles AND shreiks like a beuty! MY 5 ton has BIG SNAILS (and) BOLTS again..NO WHISTLE till U start pulling..THEN it whistles!!!??? so...I remaim TOTALLY PUZZLED still.. and dont think there IS A DEFINING WAY to tell a whistler from a NON whistler...ERRRRRR..CEPT MY deuce (which screams like a banshee and whistles great!!) HAS A TAG ON IT STAMPED C1308 ..NOW THATS whaT I call a DEFINING I.D. good luck all those seeking the differences..IF it HAS "C" on the tag...your IN. (else its try it and see!!)
alphadeltaromeo
Alto, GA
I don't notice the whistle on my D turbo if I'm not wearing ear protection, but I can notice it if I have hearing protection (either plugs or the full covering) during the shifting and then when I take my foot off the "go button".
