Do these need a raiio to work?
nf6x
Feral Engineer
1,630
50
Riverside, CA, USA
Those do need additional equipment to be useful. That headset is meant to be used with the AN/VIC-1 intercom system, either with or without radios.
OPCOM
27
Dallas, Texas
yep.. can be plugged into a little PRC-77 or PRC-25 also for some 2-way backpack radio action.
nf6x
Feral Engineer
1,630
50
Riverside, CA, USA
I could be mistaken, but I was under the impression that the headsets like this one with a "Y" cable for plugging into an AN/VIC-1 system would not plug directly into a radio because of the way the various signals are split between the two connectors.
OPCOM
27
Dallas, Texas
I thought so too, but I have used them on a PRC-25 by plugging both connectors in, as it has two jacks. I don't think it matters which goes to which. It's the same as if you used a separate mike and earphone, and in the field, some used to wear an earphone on one ear, and the handset was plugged in the other jack.
nf6x
Feral Engineer
1,630
50
Riverside, CA, USA
Ok, that makes sense. I knew (?) that just plugging in one or the other plug wouldn't work, but it didn't occur to me that plugging both jacks in would do the trick (duh!).
