Dodge 230 crank specs?
citizensoldier
17
Northern Michigan. Smelt City
re-assembling one of my engines. The crank is supposed to be STD did not need to be turned. I ordered a STD set of bearings for it. The two center main bearings they sent say .020.. When I leave them out the crank will sit down in on the outer mains just fine. The bearing set was all individual wrapped and in a box so I think they screwed up. What are the measurement for a standard crank journal? I don't have the engine manual here its at the machine shop.. Cant seem to locate the specs on my CD copy either. Thank ahead of time.
Bill W
45
Brooks,Ga
No comments from me ( not enough experience in this area ) other then I would not try using the .020 bearings.
