Dodge truck id.
uscgmatt
13
Cordova, Alaska
I have a 1983 W350 that under the blue paint it is od. It was also an ex-forestry truck, parts are that puke green. If this was possibly a mv does anybody know the designation?
Matt
xm708
vermont
w350
Matt
If it was a military rig it probbaly has some data plates somewhere. that sounds like the vintage of the dodge m880 but the chevys started right around then 83 or 84 ? are you sure the puke green isn't just a forestry color ? I see your screen name is mattuscg where are you stationed I am a retired MKC off the Reliance..
ed
1,806
RE: w350
OK Gang, if it's an 83 there is a possibility it was a civilian vehicle purchased by the DOD.Some have data plates, most don't. BTW, both of you guys neeed to add your location to your profile or create a signature with your location in it.Forum rules guys! Check the FAQ link on the left if you need help.
Elwenil
40
Covington, VA
RE: w350
Kenny is correct, there were a lot of civilian models purchased by the government for their use that are not strictly military models. some are in use by other government agencies and others are used by the military and are sometimes painted military colors but are just civilian vehicles used on base. Some have data plates as Kenny stated, and others do not, but without an "M" series designation the are not a military spec model. The OD colored Ram may have just been used for grounds work or similar duties. I have even seen a Dodge Rampage front wheel drive car/truck thing with a data plate, but no M series number, lol...
