Does an M155 tank exist..
tamangel
19
Nor Cal Coast
Hi guys, my husband got me a tank book for Christmas as I'm into armored track layers..(something in my childhood I guess...) . Anyway, have come across a question: Is there such a machine as a M155 Sheridan? When I search the web, I see it used interchangeably with M551 Sheridan, some searches mention m155 but when I get to the page, its an M551.. So my question is this actually just a regular typo and only the M551 exists or is there such a thing as a M155? If so, can anyone direct me to specs and differences so I can add them to my book..
Be gentle, I'm just learning this stuff :)
Adios,
CW
remember, dyslectics have more fnu..
Heath_h49008
102
Kalamazoo/Mich
I think the issue is the 152 mm gun that was on the Sheridan commonly being called 155mm... similar letter-number combinations.
No M-155 I know of. But if it exists these guys will know...
Paladin6
15
Northern VA
CW,
The Sheridan tank is definitely the M551. M155 referring to the Sheridan must be a typo. There was a M115 8" howitzer, but it was a towed artillery piece. Hope that helps.
Varyag
Garfield, Washington
Just check my book of nomenclature and no m155 exists.
numbering goes from M152 truck, panel utility 3/4 ton 4x4 to M157 truck amphibious, 8 ton 8x8.
edit- Is that t-30 similar to the m103 heavy tank?
L1A1
13
H'burg, VA
No. The T-30 looks like it could pass for the M26 Perishing's big brother where as the M103 looks like an M48 on steroids. Not sure how many in a batch of the "T series" they order, but the M103 reached production. The M103 was armed with a 120mm main gun which at the time was very big (required two loaders).
There was a self propelled 155mm used by the US Army in WWII. It was built on a remanufactured M3 Lee lower hull (so that's what happened to all those Lees) . As to the OP's question, I think like others have posted and that it's a typo.
Matt
tamangel
19
Nor Cal Coast
thanks Gentlemen. Appreciate it much.
I think I may be concentrating on WW2 tanks. Although armored track layers are best no matter what the era. even though I am just starting out at this stuff but I picked the M155-M551 error thing right away.
CW
73m819
319
gainesville, ga.
tamangel, If ,you do not have already, you might want to get "U.S. Military Tracked Vehicles" by Fred W. Crismon, Great track book
Paladin6
15
Northern VA
The M551 Sheridan is a pretty interesting tank. Technically not a tank though, but an armored recon vehicle, or airborne assault vehicle. Used in Vietnam, Panama, and Desert Storm. Fantastic cross-country mobility - I could take them almost anywhere, (technically they could even swim - a great capability - although it did not work out in practice). Great operational mobility as well - could airdrop them into an operational area. Like anything lightly armored, it was vulnerable to AT fires and mines, to include RPGs. The M551 with it's 152mm main gun was a great support weapon - grunts like having it around! The dual gun/missile combo had some troubles and tank on tank would have been dicey with a Sheridan, although the M55A1 had a thermal sight and laser rangefinder to help.
Wish I could get my hands on one today!
3cavtanker
Colorado Springs, CO
My dad was on the Sheridans with the 82nd ABN in the 70's. 152mm cannon could fire conventional rounds or Shillelagh (possibly misspelled) missile. Missile was similar to TOW: optically tracked wire-guided. Only problem was that usually firing a conventional round fried the missile electronics, so fire missiles first. Also had a bad habit of overheating.
As for my own experience, I was on M1A2 Abrams, so i have a hard time considering anything under about 40 tons a "tank". The army officially lists the Sheridan as a Reconnaissance Vehicle. Either way, it was air drop capable, but we all know what happens when you drop something heavy out of an airplane- stuff breaks.
Anyway, I found the manuals for the Sheridan on .pdf if anyone is interested.
Paladin6
15
Northern VA
You guys are right, some would get banged up when heavy dropped in, problems with fire control and turrets. Fewer problems with LAPES delivery as I recall. But most would work ok, and to a grunt on a DZ it was very useful having those vehicles in support for certain missions - (same for 105s by the way!) - until heavier stuff could ultimately be flown in. In this role they were a great weapon system.
Those Irwin Sheridans were indeed on their way to ultimately be scrapped unfortunately. Last location to use them was JRTC at Polk and they are done with them as well.
Would be nice to save some before they get dumped in the ocean or cut up and melted, if any are left.
