Does anyone recognize this generator?
bottleworks
Central NC
I picked up this generator surplus. I have no data on it. It has a turbo charged 4 cyl Hercules DT2300 diesel. The only data that I can find on the generator is a mostly faded wiring diagram. Any info that anyone might have would be very helpful!
Isaac-1
50
SW, Louisiana
Ok, it does look commercial, but with lots of modifications over the years, it is not Onan and not Kohler, something about the control panel look makes me think Generac. If the Basler AVR is original (do the mounting holes look factory?) then probably not Stamford or Leroy Somer either since they tended to use their own AVR's. That still leaves a number of possible bit players.
moose53
Bordentown NJ
I'm thinking Ingersol-Rand skid mounted stationary 25KV standby generator somebody converted to portable. Ingersol-Rand supplied generators to the govt, and was a major user of Hercules DT-2300 diesel engines in their gensets....
Jim
bottleworks
Central NC
Yes, I believe it's commercial. It appears to be made OEM as a trailer mounted generator. There are no data plates anywhere. I did find a timestamp on the voltage selector switch of 9/80. So, I assume it was an 1980/1981 year model generator. It looks like the regulator is OEM.
