M1009 has been parked for a year while getting axle swapped and 52 inch front sprins, shackle flip, ext. Finally went to start it and see it move under it's own power and something is really... Strange.
Something is completely blocking the fuel line between the tank and filter, as best I can tell. I pulled the filter box off and tried to send air backwards into the tank and was met with complete resistance.
Ok, so I pull the line off the tank, try to send air directly to the filter housing. Same result, completely blocked.
What is the path from the tank to the filter?Ran when I parked it, any ideas? Am I going about this all wrong? I ran out of time to fiddle anymore tonight.
