Cave Johnson
- 84
- 18
- Texas
Pretty slick.With how many of these things break, I dont see a reason to reflect on how long a printed version will last. But at least it's not 200 dollars.
I didnt have the exactly correct bolt length, but once that gets in, proof testing time in the truck.
There are a number of low/no ash filaments now that can be run through a conventional 3d pringer for people who really want to do an investment casting of something because they dont like plastic. Wax filaments if you want to go jewelry grade.Pretty slick.
The image is a little misleading on the layer question. Its got full length grain, for lack of a better term. It hasnt failed yet, but I dont use the passenger door all that much anyhow. Ill post if and when it does for sure though.Have you tried printing this in ABS? That'll do a lot for durability.
I also suggest printing it in a different orientation. The way the layers are printed make the handle more vulnerable to shearing apart along the layer lines at the screw hole and what looks like a catch at the tip of your part.
Song & a whistle. Nice!Still works. Been abusing it, but I dont have an ISO standard salt spray test or whatever for equivalent. Just texas summer and use.
I would file it under "this is an excellent option for anyone who isnt an originalist.
Anyhow, been busy arranging a 1082 to be it's buddy for a song and a whistle. That thing has no need for printed parts at all though.
There are some fairly strong plans out but I plan on machining most mechanical parts from aluminum. Not high temp printers can print very strong thermoplastics like PEEK (poly_ether_ether_ketone.)With how many of these things break, I dont see a reason to reflect on how long a printed version will last. But at least it's not 200 dollars.
Yep, I run a Creality Ender 5 Plus which is an FDM 3D printer - a bigger version of Creality's Ender 5. Lower layer height does also increase strength. Unfortunately the nature of a 3D print's creation still renders them 50%-70% weaker than injection molded parts made from the same material.Do you have a filament printer? The only issue I see is it will have poor torque strength. I tried a test piece earlier and even using higher temp and very fine layers I had a hard time getting it to stand up to the twist. Although I must say the handles on mine do take a fair amount to close all the way.
That's valid too. There are many parts that are less expensive than a 3D print or a custom-machined part and more durable in construction. Whenever I print an oddball thing for myself, I do some research to determine whether I can just buy it for less than it costs to print.I purchased my aluminum door handle with rubber covers on eBay for $8 each, I have an FDM printer but there's no way it makes sense at that price and durability level.
