scottmandu
- 36
- 28
- Texas
Part number for the headlights is in this thread.Yep. Think just broke trip. I wll pull handles and check out and also your ad. Appreciate the help. Havent had time to dig into headlights to see if 12 or 24 volt.. Figuring 24.. As on our older duece.
Nope all lights are 12v. Lots of threads in here on replacing them with various things from LED to Halgen. Bang for the buck .... and especially for Fire Service I'd recommend 100watt offroad Halogen. If you search Halogen in here your liable to find few posts and whole threads on this.... Havent had time to dig into headlights to see if 12 or 24 volt.. Figuring 24.. As on our older duece.
The pull down handles are the same as the pull up handles but the sides are switched. (ie right door handle (marked R) is on the left side of the truck. The door latch assembly is also reversed.Yes, second generation,,pull down type. Rods all there appears that handle broke in what seems normal place
thanks for your reply
Can you pm me a picture of your parts, or post up an image?It looks like my drivers door handle is also having issues. I took the door panel off and and see some kind of epoxy repair involving some rubber tubing and a nut. It looks like the rod that connects the external handle to the latch is destroyed. In addition the internal lock switch is hanging free. Is it possible to get just those parts?
Yes for certain. Today was a bit busy. First I'll be able to get back to is likely on monday.
