Door lock adjustments?
ramdough
1,729
Austin, Texas
Finally got my doors put back together and the door lock on one side doesn’t fully unlock the door on the inside. But, I can still unlock it from the outside. Is this an adjustment issue or maybe my carpeting is catching the lock mechanism?
Third From Texas
6,389
Corpus Christi Texas
Check for bind in the lever system. My passenger door didn't like being unlocked via the key. The inside latch worked but the key rod wasn't pushing the latch side of the lever system up. Closer inspection and the two parts that make up the lever system (that the rods attach to) was just REALLY tight and binding slightly. A little prying with a flat head and a hammer and it freed up enough for the key to push the rod.
Also might make sure the rod itself isn't flexing (but the OEM rod is pretty solid stuff as you know).
