Door Rod Clips (Where Our Vendor/Scalpers Get Them)
Third From Texas
6,676
Corpus Christi Texas
$20 shipped for 50 lefts and rights (you need both). That's far less than a single set sold by "community vendors" (who also will charge you another $10 for shipping).
*No point of compass website required:
*confirmed fit (these are what the A1R trucks use)
20,787
Holy Crap! 50 pieces for $8 - Buy the pack.
Use what you need. Use the others as slingshot ammunition.
Dang what a good deal... Might even be worth buying a couple of packages of Lefts and Rights!
Third From Texas
6,676
Yep, even when not on sale these can be found at most autoparts sites. They've been used in car/truck doors since the 50's.
Or you can pay $20 for a set plus overpriced shipping from....the greedy.
fuzzytoaster
3,735
Fort Worth, Texas
I bought those and they really don't work as well as the plastic bushings. The eyelets are too large resulting in slack in the linkage then the door release doesn't operate as it should. I'm staring at a bag of them on my workbench right now with mixed feelings.
Third From Texas
6,676
The 5/32" ones? Because that is what came on the A1Rs. I've worked with them in 60-70's cars/trucks forever with no issue (as you say, they have to be the right size for the rod).
Now there are throttle linkage clips that are identical that are too large, but this type clip comes in a couple sizes.
Next time I pull a door panel I'll get some tolerance specs, but mine were pretty tight. As I said, I replaced them with tacked on washers because I don't like the plastic wearing out, becoming brittle.
In any even, the title holds true.
Here a vendor link selling ONE for the price of 50:
*supply and demand you know, rare, overhead and stuff
LMFAO
chucky
19,313
TN .
They sale them at orileys 2 or 3 in the little clear hang up on pegs carton like 3 or 4 bucks and in the HELP packaging red pkgs if you dont need so many
Third From Texas
6,676
Yep, just remember that you need the L and R clips for each rod (if I recall). My first truck had several of the plastic ones that were so brittle they fell apart at the touch. I used the plastic Dorman HELP kits that had like one of each size but one broke one of the 4 tabs off while fitting it into the hole, so back to Oriley I went. And if I recall the lock rods used some that were just the insert snap (no brace clips to the rod). That was years ago, so I don't recall the price, but it was under $10 (it just wasn't enough to replace more than one rod set).
When I got the A1R I saw that they used the old-school '50s Chevy type. I ordered a couple boxes of the metal ones (a L and a R) and replaced them all. Months later I had pulled the door panel looking to see how I could mount a small LED that would illuminate entry. It dawned on me that I could tack a washer onto the rod, so I pulled all the clips and did. Haven't messed with that truck's rods since (over a year I guess).
I re-did both doors for a buddy last year since it was a '97 and I had the clips on my workbench. I'd forgotten about them until the other day when they came up in a discussion online. I was trying to find the link to Henry's when I noticed that they were on sale yesterday.
While I doubt my tacked-on washers will ever fail, I keep a baggy with a few sets in my truck tool box. If I even have to pull a washer off with a pair of plyers to fix something else in the doo while on the road, I can slip on on. Quick fix and I can be back in action. But honestly, I'd rather have the piece of mind that they are welded on. ymmv
I doubt anyone will ever need 50 of them (unless you want to start selling them to fellow community members here for $10 ea and get rich). ;)
I just wanted to pass along a good deal. Because if you've ever replaced one, you've likely replaced another eventually. And another...
coachgeo
3,551
North of Cincy OH
this has been discussed in here over and over... nothing new presented here so far*. But in case folk in future searches find this thread first..
surprisingly... for longevity the plastic is better. The plastic is sacrificial.... it will wear....or age out as mentioned in here. Metal clips puts the metal rod into the lock/latch hole and holds it there well... for years in fact..... BUTTTT it bounces around, slides back and forth there; rubbing metal on metal (and rattling) which wears out the rod and wears out the hole it is going into. Now you or the next guy..... has worse issues many years later... elongated holes and worn out ends of the rods.
I used Dorman universal pack of plastic rod clips (maybe 8 various clips per pack?) available in most every auto parts store... took two packs to have enough of the right size to do a side. drilled out the plastic a hair to fit the rod. The clip's end that fit into the lock/latches hole was fine.
*both metal and plastic clips folk have used before are listed in the Yellow Parts Spreadsheet pinned/stuck to the top of the Fmtv Forum here on the Steel Soldiers Discussion Board.
coachgeo
3,551
North of Cincy OH
Except the price that doesn't f*** the community members up the a**
So you're pretty much mistaken....
that has been discussed too .... a lot actually
the ones listed in the spread sheet are NOT the expensive ones. They Yellow spread sheet started by Wes Simpson ( @simp5782 ) is intended to be more over the counter-ish, user tested, and less specialized when ever possible.
chucky
19,313
TN .
I had bought one of those boxes from horor freight of what looks like thin flat washers but they have little cuts in them so you can push them on the end of smooth rod and the teeth keep it from coming back off the end and i wound up using them on my rods in the door on the passenger side when i first got my truck they had robed the door stricker latch and i had to make my rod i didnt have one of those either ! But the big question out of all this is when the IRS will let us write off these trucks as a dependant !!!!!!!
20,787
Heck of a plan Chucky!
We can claim these trucks as dependents as soon as we finish paying off the debt from all the people who have been sitting home on their butts collecting a check. Hellen Waite is in charge of that government program. If you want to be a part of the new plan, go to hell and wait. :)
wheelspinner
1,539
North Carolina - FINALLY !
Well both are out of stock already.
