Dot 5...
3rdaavbn
Suwanee/Georgia
Can anyone tell me the DOT5 brake fluid capacity on the M35A2?
Mine is about to be looked into and I want to make sure I bring enough for filling and of course bleeding.
swbradley1
Modertator
1,628
Dayton, OH
Start with searching the site. It has been covered many many times.
A gallon will do unless you want to completely flush the system a couple of times then just get two gallons.
2002 DOT will be just fine if you keep the cap on the jug/can.
DieselBob
13
Arnold Maryland
As long as it has been in a closed container so not foreign material could contaminate it you should be fine. It doesn't absorb moisture like DOT3 which is what kills it over time.
welldigger
15
Benton LA
I think 2 quarts was more than enough to do my truck. And that was after rebuilding the mc and replacing the air pack. Then I flushed each wheel cylinder until nice clean purple fluid came out. This was all done with my home made pressure bleeder.
