Double tapp U joint # jack shaft
Westech
CPL
6,104
207
cow farts, Wisconsin
I searched 220 posts in the deuce Forum that stated U joint and "Think" I found the correct Jack shaft part number.
Precision 332
is this correct?
Anyone have any other Cross reference numbers?
(This is the U joint for the shaft from the Transmission to the T case with the bolt on plates)
1,817
There can be 2 different ones. All of mine have bolt on caps but desert rat had one with clips. I would utilize the ODIron site as a possible reference.
bigjoe
Madison NH
I bought a precision 332 the other day from napa for the shaft that goes from the transfer case to the front rear axle. This is for the bearing plate style, not the snap ring style. I checked the OD IRON site and it says that the part number on their site for those two u joints are the same. So I think you've got the right number. However the u joint was very expensive through napa ( almost 100 dollars) so I would order through OD IRON.
m-35tom
221
eldersburg maryland
as far as i have ever found there are only 2 'u' joint numbers for the duece. 332 for the large ones and 330 for the small ones. shop around, napa and some other places have really high prices!!
tom
