Drag Link Part Numbers
rsl0311usmc
NC
I am having trouble downloading the correct TM so I can locate the part numbers for the drag link. I am wanting to replace both ends and sleeve if someone has the correct part numbers for oriellys or autozone. My tire has tore up the one end and regardless it's all worn out and needing replacing
Buck69
90
Northern British Columbia
I replaced the both the drag link ends with Moog just because the rubber boots were badly cracked and they had lost their sealing capability. Our local parts store had them complete in stock for not much more than just the boots themselves.
You can also look almost everything up and order online if you find it easier with companies like Rock Auto or Napa. Just search under 1984 K30 with 6.2 for vehicle specific parts.
rsl0311usmc
NC
autozone.com/searchresult?searchText=drag link
There you go and it's in A C Delco and everyone gets a SHWING when they see A C Delco.
autozone.com/searchresult?searchText=tie rod ends
I have used every type of part I can find and they all work till they don't work anymore. These all have lifetime warrantees. Good Luck.
Alot of that says tie rods unless the tie rod ends are about the same as the drag link ends? This is what I ended ordering from parts geek. My part numbers were AC Delco 45A6002 (adjuster sleeve), AC Delco 45A0195, and AC Delco 45A0194. One end is like six something inches and the other eight something I believe.
rsl0311usmc
NC
For some reason my search on there for that exact thing came up with unavailable parts. But below I listed what I found on parts geek of all places.
