drag link questions
JasonS
188
Eastern SD
Anybody know the difference between the gasser (7521371) and multifuel (10897161) drag links?
Are the ball studs the same (1.25")?
Anybody know the ball stud shank diamter at the narrow end?
Thanks!
Stretch44875
Super Jr. Moderator
31
Tiro, Ohio
I would think they are the same. Not sure why the different part number. When I converted the M108 to mulitfuel, I think I used the multifuel drag link. Just because it was in better shape. Actually, I ended up putting all the steering parts from the mulitfuel on.
gringeltaube
Staff Member
2,650
Montevideo/Uruguay
Gasser draglink is 5/8" longer (at the st.knuckle end). Everything else is the same for both.
Nominal ball diameter is 1-1/4" (measuring exactly 1.244")
Shank diam. (on steering arm ball stud) is threaded 5/8"-11, cone starts at little over 3/4" and goes up to 7/8" max.
G.
Stretch44875
Super Jr. Moderator
31
Tiro, Ohio
See, someone knows more than me! Wonder why the longer draglink. Steering box and axle are in the same spot on gasser's and multi's.
