Drain oil pan
m16ty
211
Dickson,TN
At work we have a big pan with a spout that will hold 11 gal. We've had it for years and I have no idea where it came from. To change the oil in the deuce at home I cut a plastic 55gal. drum off so it would fit under the deuce. Only problem is it's hard to pour out with no spout without making a mess.
WillWagner
2,553
Monrovia, Ca.
2 five gallon buckets work fine, one for the rear, one for the front. As for the filters, just let it sit for an hour after it is started and there will be no oil in the cans so it won't be a mess.
kaiser2help
East Freetown, MA
I purchased a large oil drain pan from my local truck parts supplier. I believe the gas can company ( Blitz) makes it. I use it to drain my 5 ton with ease. It even has wheels mounted at the rear if it gets to heavy to pick up alone. You can still use it by yourself till you get help to pick it up and drain it. I paid 70 $ bucks about 5 years ago and it is worth every penny. Try Blitz.com. Good luck.
bulldog_mack13
3/3 ACR
2,969
34
Colo Springs, CO
Changin my oil also now with Johns filter kit. What front plug are you guys talking abouut ? i thought all you have to do is pull the oil pan drain plug then filters after... :|
otisroy
Melbourne, FL
I second that. I'll see what happens with the spin-ons. I was thinking of laying some foil around the base to catch any that runs out. I used to do that to keep the oil off my headers on my sportbike.
