Drain plug
pwrwagonfire
Central Massachusetts
I know its a long shot....
But does anybody know what size rubber gasket their M37 or power wagon has on the oil pan drain? I am gonna need to get a replacement for a '64 WM300 and wanna try and get a ballpark before hitting the parts store!
I have the plug pictured in my head....but I got nothing on the measurements!:roll:
longshot2171
Ballston Lake, NY
I think it calls for a 7/8 inch. Napa has normally has metal ones behind the counter. If you want the thicker nylon ones try looking in the oil plug section at your local parts store. I picked one up at advance auto a for a few bucks. I think it was made by either motor-mite or dorman . If not try either vintage or midwest...
timmmaaa06
Chciago il
Oil pan Gasket
Hi I replaced the oil pan gasket and there was a bag with two pencil thin rubber rods I do not know where they go. the gasket cam from napa and is the cork type material. I have a leak in the back of the pan between the clutch and oil pan its self I do not know where if those two rubber rods were for something. thank you I have a 53 m37. antifreez is driping occationaly from that area as well.
T. Highway
53
S.E. WI & S.E. TN, USA - Earth
If you have a T245 and installed a Victor style rear main seal it will not seal correctly. The anti freeze may be coming from a rusted out freeze plug.
Here is the only rear main seal that will work if it's not a bolted in style.
Bert
