Drash Generator power distro box
Poccur
134
Roanoke, VA
So far as I know these rarely come up on auction so I was fortunate to snag one. Generator has a 60amp connector that is three-phase, these are the boxes you hang on the end of that cable to break it out to normal 120V single phase for use inside the shelter. Works with DRASH, PowerSystems, MEPS...Stand keeps it up off the floor...
98G
Former SSG
4,424
Various iterations of those boxes are readily available. They vary in input from 40 amps to 200 amps of 208v 3 phase. Output is usually 120v single phase and a pass through for the same 208v 3phase that goes in, so you can stick several of them together.
Some of the larger ones only have 3phase output, but the 40 and 60 amp versions split it to 120v single phase.
