Drash Genset ECU Trailer
jamawieb
542
Ripley/TN
Poccur has a huge amount of knowledge with these so listen. I assume someone retro fitted the screw on terminals because I havent seen them on a HDT unit. The ones that screw on probably go to the slave receptacle which are not needed unless you wanted to jump it off.
Poccur
134
Roanoke, VA
You are very kind..
You are exactly right, one of the side terminals from each battery is fed across to the NATO receptacle.
No contact from the OP yet...
