drilling brake drums
benand117
cuyahoga falls, oh
whenever i drive through the creek i don't have brakes for a couple of miles. what do you guys think about drilling the drums. i know guys use to do it to jeeps back in the day. don't see why it wouldn't work on the deuce.
1,176
Is your shift key broke?
benand117
cuyahoga falls, oh
i don't even know what a shift key is. i think it's just wet brakes. if i ride them for a little bit they dry up and work fine. i hear the holes let mud and water out. atleast thats what the old guys, (my dad), say.
1,176
I can tell you don't know what a shift key is!
It's the key to the left of the letter Z.
1,176
Holes will let it in also.
Unless your truck is ONLY used off-road, I would not drill them.
dozer1
13
Sargeant, Minnesota
I would continue drying them out like you do. Ride em a little and there dry. The possibilities of doing more harm then good are there. I googled this and that was their general opinion on some other forums too.
phil2968
Lakeland, Florida
It's not just him it bothers, it bothers a lot of people. You might get more and better responses to your questions if you took the time to type properly.
Even disc brakes fade when sunk in water and need to be dried. The deuce brakes are bigger and carry more water, drilling may help relieve some water carrying but they will still need to be dried.
mdmorgan
AM3 U.S. Navy
1,085
102
Forsyth, Ga.
If you lightly drag your brakes while going through the water it should help them to dry even faster cause water wouldn't be able to get to the friction surface as easy.
dozer1
13
Sargeant, Minnesota
:funny:
Don't the drums already have holes somewhere for this reason? Someone had told me about this once.
I think there is a few well placed holes. I know when I had a leaking wheel seal that the oil escaped from those holes and didn't get on the shoes. I thought that was pretty cool.
benand117
cuyahoga falls, oh
There are a few hole in it already, but they're around the edges. I figured if they were in the braking surface it would let water escape even faster. I just can't see drilling them could hurt the integrity of the drum, I mean they drill and slot rotors and the hold up in race cars.
1,176
If you drive it on the road legally, and you have an accident, I think you will regret ever drilling the drums.
There is a big difference between a rotor and a brake drum.
1,128
The Army planned on driving them through water...... enough so that there were factory fording kits and they chose to have the drums as they are (undrilled).
Heavysteven
10
Hickory Flat Ga
Best option would be to take off the inspect plates.
I am hesitate to even respond because I bet your bearings have had all the grease washed out.
Water above the hubs means mucho pcms.
khandoh
Warner Robin, GA
Rotors are drilled and slotted mainly on ABS applications to dispense some of the heat, as they can get very hot. Generaly speaking, large heavy brake rotors are kept, as brakes convert kenetic energy to thermal. The more mass to absorb heat, and the more surface area, the better.
Tow4
640
Orlando, FL
:ditto:
Just remember, bigger holes let the mud and other garbage in easier too. If you are going to play in the mud, pull the drums and clean everything up when you are finished. I learned that lesson 30 years ago in my mud truck days. It doesn't take long for the mud to chew brake shoes and drums up. Not to mention bearings and seals.
