Drive line angle
Bill in pa
40
homer city pa
I have a carrier bearing and a slight vibration.
Any ideas how to change the angle to solve this?
Rear of trans is 3° up.
Front shaft is 1° down.
Rear shaft is 0°.
Front of to tandem is 1° up.
Bill in pa
40
homer city pa
M35A2C quad cab.
Im thinking I need to lower the carrier bearing slightly.
To me that's my only option.
Being the engine/trans/transfer are factory positioned.
As is the rear axles
From what I have read, no angle should ever read "0".
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
Yes, it is also the easiest to give it a try and see if any changes/improvement, after that.
As a first step I would not exceed 1° between T-case and first portion of rear prop shaft. Ideally, this one should be like an "extension" of the TC output shaft and then the angle after the carrier bearing should be the same as the one at the first rear axle input.
WillWagner
3,179
Monrovia, Ca.
If the rear of TRANS is up, look at the front mount. Was that moved when the cab was added to?
You DO know that these trucks vibrate, shimmy, wiggle all the time. How can you tell :p
