- 4,210
- 37
- 0
- Las Cruces, NM
Found something interesting today. I was prepping this truck for sale, and during the bolt tight check between the tranny and t-case I found these non-shouldered bolts on the left, 3 were installed on the intermediate shaft and 1 on the front axle drive shaft. The correct shouldered bolts/nuts are on the right. This truck came straight from the NM NG, just a heads up to anyone who cares. As you can see the bolts/nuts are different, and were causing a slight vibration because they were mixed in with the correct bolts, slightly different weights, after I swapped out the bolts for the correct ones, the vibration was gone.
Ed
Ed
