Drivers door window
Duace
st.petersburg fl
I recently had a problem with my drivers side window. It just came off the track one day,just as i was heading to a car show. So when i started to research the problem through the access panel and found the regulater arm out of the track, so i worked on getting in back on with those funky clips. It worked for a day or so, popped off again. Now window is stuck, wont go up or down , clip fell off again. Window is all cattywoppis. What a pain in the (you know what) no room to work or see. Has anybody had this problem and is there a easy way to fix this and get to it? Appreciate some advice....Thanks
