Driveshaft to pinion u joint retainer bolts.
rcamacho
827
Bainbridge Island Wa
M1151A1.
Removing rear diff for service. The driveshaft to pinion bolts are stuck well. Tried WD40 in the back side of the bolt hole bores along with mapp gas heating. No joy.
Trying air hammer flat anvil on the pinion next. Then destructive removal.
Any other suggestions?
Mogman
9,223
Papalote, TX
Well at least you will not break the bank if you have to replace it.
Mogman
9,223
Papalote, TX
Dang, when I built the DuraVee the largest yoke I could find was the 1330 series, now I see them in 1350 series.
Not that I have been able to break the 1330 series U joint ;)
The early trucks like the M998 used a 1310 series U joint.
rcamacho
827
1350 and 1410 series are
