- 3,021
- 222
- 63
- eldersburg maryland
OK I have a 94 A0 that has driveshaft problems. So what I find is that these trucks came with the driveshafts not balanced at all. Seems stupid. Then there was a program to replace the shafts and stamp a D on the dash plate. My truck came with those shafts and 2000 miles. The rear shaft has .050" side play in the slip joint and .080 side play in the front shaft. This is WAY more than even remotely allowable. Spicer says max .003. I bought a new shaft but it did not have any balancing weights so I had it balanced and installed it. No side play in slip but it has not been driven. Is this shaft going to fail? It seems to me that there were simply defective shafts being used up to about 2000. Many large trucks go 300k and way more on the same driveshaft, Why can one of these trucks not even go 2000 miles? Yes I have read the published info about the shaft problem but I don't completely believe it. There had to be a serious problem with the manufacturing of the shafts for them to fail. Any insight into this appreciated.
Tom
Tom
