heinsite
- 0
- 0
- Atlanta, GA (Dunwoody)
I just picked up an 86 M1009 and learning fast that things break often..Anyway, on two separate occasions after turning once left and once right, the truck comes out of gear. When I stop and try putting the shifter in park, it grinds. To correct the problem, I have to place the 4wheel shifter in 4wheel low, drive a few feet, disengage and the transmission is fine again. I also know I probably need Ujoints as well, because when I let off the gas I get the slight clank and the same when I accelerate, I assume these are separate issues, but not sure.
Anyone know why transmission is doing this or where I should start?
