Smokingman
- 1
- 8
- Two Harbors MN
M1009
I heard two very short ping ping sounds,then nothing abnormal.Thought I may have a little bit of unusual vibration as I continued.
I left the truck running and got out to investigate.There was a decent wobble in the harmonic balancer(not horrible,but enough).Finished driving it home.Taking a closer look I could see a shinny ring around roughly 1/3 of the balancer.
Took it to a friends shop.We pulled it.Sure enough it had rotated a good 1/4 of a turn.Went to install the new one.And ran into a snag.Had no bolt that would fit.We ended up ordering a one meter bar of allthread and nuts from Fastenall. Cut it down and used the stock washer and a piece of all thread.
Just an FYI there was a post earlier about using the puller from O'reilly.It is a standard thread,though very close.I would not use it unless you want to mess up the threads on the end of your crank.
She is back on the road none the worse for wear![A toast to MV's :beer: :beer:](https://www.steelsoldiers.com/images/smilies/beerchug.gif)
