Hello
Soon on SS I will have my double alternator as a vendor. Just waiting for Paypal and credit card merchant approval.
I can answer basic questions without trying to sell you.
Niehoff and others try to sell you a dual voltage alternator output. While this is true you get 2 voltages, you are limited to total watts the alternator can produce. For instance the popular 100 amp at 28 and 14 volts only has 2800 watts. The alternator produces 2800 watts at 28 volts max. It uses CRT technology converting 28 volts down to 14 volts as you need it.
It uses diodes and a regulator to make it happen. If you load it with 14 volt stereo, AC, Big amp lighting, all at 14 volts, it then has little 28 volt power for the engine and transmission, gauges etc.
More to come
Double Alt
