fungus
- 79
- 18
- Western North Carolina
Hi all,
I've been doing some digging and some great information is available on the site for prior conversions. A gentleman had done a hydromax conversion in the past from a unit pulled from an International S1700 IIRC, but he tied both circuits together and fed the original single brake line. spicergear's thread link
I am getting a system from a 2003 International 4300 that I am going to _try_ to put underneath the cab using the original deuce brake pedal and lever. Just in case, I'm also snatching the brake lever assembly from the 4300. In the event plan A doesn't pan out, plan B is to firewall mount it.
Toward the rear of the truck, just behind the airpack is a splitter. The back half feeds the back two axles, the front half feeds the front axle. I intend to route circuit A to the front axle and circuit B to the rear.
You can see the spoken of fitting here, just under FL2:
Since I will be ditching the air booster and single-circuit master cylinder, I need to ensure the other air-operated items are still properly supplied. I would like to keep compressed air on the rig for the sake of tools and the occasional air brake trailer I need to jockey (not to use the brakes, just to keep from having to cage them all).
The following diagram has a complete system, but has very little markup. Additionally it seems to show hydraulic (brake) lines as well as pneumatic lines with no differentiation.
Does anyone have a better pneumatic system breakdown that identifies the individual components? I seem to even have air lines going to the fuel tank, I have no clue what's going on there.
For the uninitiated, the Hydromax system uses the power steering pump to provide boost rather than compressed air or vacuum. In addition, it has a backup electric pump that will provide that "last effort" braking in the event of engine failure. It's a very robust, modern system with plenty of failsafe. If you're already going the power steering route, it seems like a win to make this jump as well. I'm biting the bullet up front, as I need to overhaul/replace the booster and master cylinder. By piecing things together, this is a cheaper system than rebuilding/replacing the OE air-assist parts.
*nipping the bud*
Before anyone starts freaking out about proportioning valves, remember that the single circuit system routes equal pressure across all slave cylinders. Also remember that a dual circuit master cylinder will independently provide the VOLUME of fluid necessary to create the PRESSURE required in both circuits. In other words, if you command 1500PSI with your pedal, you should get 2x the fluid VOLUME in the rear circuit (4 slave cylinders) vs the front circuit (2 slave cylinders), leading to 1500PSI+/- in both front and rear. All slave cylinders should see the same pressure.
DEUCE BRAKE LINE REFERENCE GUIDE (Sizes, lengths, fittings)
POST 1~ SINGLE CIRCUIT BRAKE LINES POST 2~ DUAL CIRCUIT BRAKE LINES POST 3~ BRAKE PARTS REFERENCE GUIDE POST 32~ BRAIDED STAINLESS FLEX LINES/HOSES POST 40~ DUAL CIRCUIT MASTER CYLINDER BRACKET INFO & CAD FILE SINGLE CIRCUIT BRAKE LINE INFO I've been selling Stainless Steel Braided Flex hose...
www.steelsoldiers.com
