Dual exhaust for my bobber
ranchhopper
139
south elgin illinois
Had some time today so I went digging around in the scrap steel pile behind my shop and started making the brackets for my dual exhaust.I had some old peices of M52 stacks so I welded them together to make them long enough to look right.Im going to split the exhaust right behind the cab after going straight off the turbo on the cat engine going in the truck.This is all that can be done on the exhaust until I can sit the cab on the mounts and route the pipe off the turbo to the Y and clamp in the 90s at the base of the stacks.I wanted them away from the back of the cab for better heat dissapation the whole back of the cab and hard top has one inch thick insulation sound deadening material we use in heavy equipment cabs.
