- 1,817
- 1,131
- 113
- Ostrander, Ohio
Does anyone here use these? I bought some 4x16" ones (10,1, and 0.5 micron) and the disk they fit on and I'm trying to figure out the best way to use them. For simplicity sake, I'm just plan on using gravity to provide pressure. I'll have a reservoir at the top made from a 4" PVC pipe, that will feed into about 24' of black iron pipe with heat tape on it to heat the WMO up. From there it will drop down to the sock filters. This is the part I'm not sure on. I'm thinking of just having a 2'x6" PVC pipe with a reducer at the bottom as sort of a funnel going to a barrel. I would like to be able to pressurize the system, but I don't have an idea how use the filters in an enclosed system. The WMO will start out from a drum of oil strained to 100 microns and settled for a month. I then plan to run it through the 10 micron sock, athough if I can figure out how to pressurize the system, I'll also run it through a 5 micron filter with a water block into a drum. I'd then run it through the system again but through the 1 and 0.5 micron socks stacked. I'd like to see any other options before I commit on this, comments?
