Dumb idea?
M715ForLife
Exeter
My dad and I have 2 winches for the M37.
One on the front.
Would it be a good idea to put the winch under where the fuel tank is, and run a hydrolic line?
Then make 2 fuel cells across the frame rails, 20 gals on each side.
Then, cut acess hole ontop of the winch?
Good idea, or waste of money?
spicergear
27
Millerstown, PA
I did this on my M715 way back when it had Locked Dana's under it before the 'Rocks. I swapped in a dodge fine spline divorced NP205 (as the stock NP200's hadn't a PTO port + the 205's don't overheat) then got a Muncie PTO for it. Got the PTO from ptohydraulics.com, iirc. It's got 150' of 1/2" wirecore cable and a lead of high grade German alloy chain and a lockable grabhook. Yep, it's a 10K Garwood from a deuce...as is the one up front. Modified 5 ton driveshaft works well. It's cool and got some serious "AWE" factor as I drove over a high obstacle at a Jeep event and everybody in the stands got a view of it, a buddy was in the crowd. That being said, it's nearly a $300 buck PTO, over $150 in cable, chain, hook, etc...and I've used it once. ONCE to rescue myself. Cool? -yep. Save ya an extraction charge? -yep. Entirely worth it? :shock: ...insurance of it is nice...and tough to beat the cool factor. HA! :D
