russojap
- 0
- 16
- Knoxville TN
What is the circular recessed(milled out?) area around where the canister tube goes in, it looks like there should be some kind of rubber gasket in there?
I'm not crazy about this setup, I had to keep vacuuming rust off the filter housing base. I know it probably shouldn't have been rusty to begin with, but it was, so I had to deal with it. Does the dirty oil come up the tube and this is clean oil we see in the pic, or the other way around?
I have to figure out how to stop the rust on these.Thanks
I had to knock and pry the canisters loose, but this is also the first time I've changed the oil in the eight years I've had it.
Also, I read somewhere that the engine should not be started , but needs to be allowed to crank only for several seconds to allow oil to reach the turbo., That doesn't make any sense to me because I don't see what would be the difference between the truck not running for some time , and draining the oil. Is there a special starting procedure after an oil change?
