Here is a few pictures of a dump conversion my brother and I recently finished.
The truck works great. The box dumps at a 45 degree angle. Plenty far for gravel. I've hauled 5 loads so far with the truck without any problems. The box could use taller sideboards though. 5 ton of gravel fills it up over the tailgate. I suspect the truck is capable of hauling far more than the 10,000 lb highway rating. It has plenty of power to move down the road.
The cylinders are 4" x 45". The hydraulic pump is a 14 gpm that was borrowed off another truck. The pump runs off a chelsea pto and driveshaft. Very easy install.
The c channel rails of the box were fitted with 3 x 5 1/4 wall tubing. The cylinders push on another 3 x 5 tube to transfer the weight. The hinges are the same tubing with a bushing we machined out that crosses the entire tube and welded into place.
