Economical turn signal flasher repair option
papakb
1,185
San Jose, Ca
On my last outing the turn signal flasher died in the middle of the Veterans Day parade. I didn't have another one on the shelf so I went looking for a solution. What I found was a 12-24v flasher unit from Grote (44010) that will work with both regular lamps and LED lights up to 12 amps which should be plenty of current for our vehicles. The best price was on Amazon at $29 with 2 day delivery. This is what I did when I received it.
Here's the flasher and the gutted Nartron flasher unit:
Make sure not to cut the pins coming into the case from the 3 pin connector. You need to solder the wires back onto them.
Remove the heatshrink from the wires on the flasher and cut the leads to about a 3" length and tin the ends of the wires:
Solder the cables like this:
a is the flasher output (green)
b is power in (red)
c is ground (black)
Here's the finished flasher. It could be potted with RTV for waterproofing if necessary:
Final cost was about $32 and an hours work. When it's remounted it will look exactly like the original because the Grote flasher is on the top side of the original one behind the dash.
Kurt
Jakelc15
37
Hanover Pa
That's awesome. My flasher died a few months ago. Truck-lite makes the replacement but was unavailable from my local supplier. And was also very expensive if he could have gotten it.
I was wondering if I could gut the factory flasher and save the connector.
Thanks for posting.
papakb
1,185
San Jose, Ca
That's exactly what I did here. The Nartron flashers are pretty easy to gut, I haven't tried any of the other models out there. I've ordered a couple of the connectors that mate with the wiring harness connector that can be put directly onto the flashers wires then all you would need would be to make a mounting bracket for the flasher. I'll do another post with that information when I finish it.
Kurt
BBQROD
-13
Gray Georgia
I went to the parts store and bought a 12v electronic flasher the one with three prongs input+ Lamp output+ and Negative Ground I connected everything by the book except for the ground on the flasher. I connected the ground of the flasher to a dash light bulb socket, a GM plugin type from the mid 80s. The bulb measured around 8 ohms resistance with my volt ohm meter. you connect one leg of the bulb to the flasher negative and the other leg to ground (chassis or cab) the bulb being in series absorbs the extra 12 volts that the flasher electronics does not want. my M35A2 has been blinking away with no problem.
papakb
1,185
San Jose, Ca
If you look up under the dashboard everything looks stock. The original connector is still attached to the flasher unit and no one can tell that what's installed is a better component.
1,129
You can just buy a standard automotive blinker relay in 24V.
2 or 3 terminal.
Tridon eg-22 or eg-23
OK, question.
The factory relay on our trucks have 3 circuits: constant power in, flashing power out and ground.
It appears the relay you spec'd (EG23) has 3 pins: a constant feed in, a trigger from presumably a turn signal switch and a flashing power output.
See:
Flasher Quick Reference
B, X, + 49 = Battery (Power Input)
C2 = Hazard Switch Ground
E - 31 = Ground
H = Hazard Switch
I = Ignition
L, 49a = Load
P = Pilot Lamp
S = Sense
Or:
So does anyone know of a part # for a civvy 24V flasher with three pins, for ground, power in and flashing power out?
Gracias
C
1,177
That is how that one works, and the other one simply does not need a ground at all. (power in, flashing power out)
I've been using them for some time now, and they work well.
1,177
In the schematic, the portion I boxed in red is representing your turn signal switch(left and right option).
1,177
I prefer the eg-22, it eliminates ground failures at the relay mount.
1,177
To further clarify, if you choose to use the EG-23 flasher, the terminal connections are as follows.
relay X-input, truck wire number 167, flasher plug letter B
relay P- Ground, truck wire number 90, flasher plug letter C
relay L- flashing output, truck wire number 19A, flasher plug letter A
1,177
More part number for the same relay
Replaces:
Buss 234
Carquest FSH23
Grote 44860
Littelfuse FLR234
Napa EG23
Tridon EG23
Signal Stat 121
Trucklite 263-4
Hella 87723
TOBASH
3,474
Brooklyn, NY
Awesome post.
Re-activating to ask:
Will any of these relays activate and work with LED light assemblies?
simp5782
Feo, Fuerte y Formal
9,367
Mason, TN
Awesome post.
The grote flasher is pretty cheap and work well. You just have to remove the light bulb from the turn signal lever itself and replace it with an LED otherwise the turn signals won't work with that bulb in and everything else is an LED.
TOBASH
3,474
Brooklyn, NY
Any source and style of LED I should order/order from?
TOBASH
3,474
Brooklyn, NY
To replace the light on the turn signal to allow LED lights and indicators to work
simp5782
9,367
Mason, TN
depends on which turn signal you have. There are several different variants out there. Won't know till you open it up.
