jasonjc
- 283
- 83
- Gravette Ar.
I will start with the last time the truck was started. The batts were weak and the truck did not start. So I jump it with the deuce. It started and ran fine. I shut it off just fine then restarted it on its own power just fine. Shut it off again with the start switch. No proplem. Shurt off the battery switch worked like it should. Unhook the jumper between the truck batterys ( jumper cables were removed earlyer) to charge them. They sat for weeks unhooked. I went to start it the other day and all seemed all right. Shut off the start/run switch eng died like it should. Then truned off the battery switch and seen the the red light (brake) stayed on, looked and seen that the gagues and other stuff was still on too. Retryed the switch and still power is still on. Unhooked the jumper (dog bone) and left it for the night. Next time I went to try it , I hooked up the jumper and the air buzz came on, with the power switch off, all the other stuff that should come on with the battery switch was on too. But the switch was still off. I also herd a relay click as soon as the jumper tuched the battery post along with the buzzer going off (on). I thought the switch was bad so I pulled it off and unhooked it. Still all the stuff were on. I put the switch back in and tryed tapping on the control box, thinking the relays were stuck. The only thing that did is seem to keep the start switch from working now. The only way to trun off the power is to unhook the battery. I pulled the box thinking the relay was stuck. I put a omh meter between the two big pins I get nothing like you should.
Now where should I look next?
I see threads with no power, but not power staying on?
