Electric Brake Controller
quickfarms
24
Orange Junction, CA
Are electric brake controllers proportional?
There was a post a couple of days ago about using a relay tied to the brake light switch to control the electric brakes.
Is it necessary to use a proportional controller or is the relay ok?
Is there any issues with the brakes being on or off?
R Racing
St. Leonard, MD
Proportional is much better to adjust for you different load conditions .Like with a empty load you dont want to drag your trailer tires. And if you have a heavy load you dont want the trailer to push you down the road.
jaxsof
15
Dundalk, MD
All of the ones I"ve seen are proportional. They have a little pendulum in them so if you're stopping faster, it will know to apply trailer brakes harder
KsM715
142
St George Ks
:ditto: If you wire a relay from the brake light circuit straight to the electric brakes it will apply the full 12V causing the brakes to lock up.
