SsjSned
- 0
- 0
- Stamford N.Y.
Hi guys my cucv has original 24volt hooked up still.When I got the truck no lights(head,turn,hazard,brake),black out, or horn would not work(well not sure if the black lights are on or not bc last owner painted over lenses but hitting toggle switch dosnt turn lights back on). it dosent have the glow plug module/relay thing next to the brakes on the driver side so glowplugs dont work.To start the engine i had to put 1 sec of ether in filter and the starter still worked.Engine runs fine with 40k miles. turning on the key only GEN 1(driver side) would light.put new belts on engine.The powerstering mount for alt tension bolt is cracked off(cant really tighten the belts).The engine used to shut off ok but then it started to diesel with the key out.(Had to plier the fuel drainback line to shutoff). Thought maybe the shutoff sol was bad or dirty. Some one told me to check if it was the solinoid or a diff elec problem causing it to diesel by taking off the wire to the top of the IP when running to see if it shutdown.When i went to start the truck back up no crank no GEN 1 light nothing?. also my wipers stoped working when she was running last.
no fuses seem to be blown in the panel. What is the most likey problem? Want to just fix the problem of not starting then ill fix the lights. Any help welcome thanks
