Electrical distribution blocks
Jeepadict
783
Round Mountain, NV
Along the way I've added a CUCV component here & there to my 78 K25 as I find they give added versatility to my multi-role monstrosity. (Rear bumper, bed tie-down eyelets, etc...NP208 PTO is likely a pipe dream)
My current consideration is adding the multi-point electrical distribution blocks. Given the intended re-purpose these would lend to powering accessory relays for things like lights/amps/inverters/trailer connector power, etc. The CUCV block would (in theory) alleviate the burden for the OE 2-post distro block (pictured) adjacent to the master cylinder assembly on the firewall as this accessory post is fed from a far smaller 12/14 ga wire.
Any suggestions/reccomendations or pros/cons to this thought process? Any thoughts of what a safe load maximum these blocks could support? Anyone have a general description or pictures of how these were used in the OE CUCV application? I'm sure there's a TM for these parts, but I'd rather hear from the horse's mouth. TIA
Sent from my SM-G970U using Tapatalk
MarcusOReallyus
819
Virginia
Well, the diamond shaped block near the booster is used by many to run their glow plugs, which pull 80 amps. That's in addition to the normal load on it.
You are probably safe with 100 amps on that one.
The others are beefier, so....
