Electrical issues M1008
CPYoung66
Windham, Maine
I have an ‘84 M1008 and cannot hold a charge....I’ve replaced both batteries 2x, had 1 bad alternator rebuilt but if I don’t start/ run it every 2-3 weeks it goes flat. There is some sort of electrical “leakage” but I have no idea where to look or how to track it down. It’s become such a PITA, I’m considering converting to 12v just so I can jump start it with another vehicle.
all lights off, hood 24v solar trickle charger works, and the “all off” switched next to the black out light switch.
any thoughts suggestions appreciated
cucvrus
10,432
Jonestown Pennsylvania
Converting it to 12 volt is not the answer. Do you have Gen 1 and Gen 2 idiot lamp when you turn the key on? That is where you start. i just had a plow truck converted to self exciting voltage regulators and now the lights don't have to work and the system charges as designed. Converting something that doesn't work to begin with is like crushing the vehicle and trying to rebuild it again in a different way and have the same results. You still have the same issues and more issues now with a different voltage instead. Good Luck. Happy Holidays. May I suggest you pay a knowledgeable person to do the repairs?
Keith_J
1,323
Schertz TX
What are convoy night lights?
Blackout marker and brake lights. These are LED. The front drive light over the bridge plate holder is the blackout drive light.
These are 5 MPH max speed lights, only useable on moonless nights.
Keith_J
1,323
Schertz TX
To find the parasitic drain, rule out the fuse circuits by pulling fuses one at a time, then using a voltmeter set in the amperage measurement mode as the "fuse". Do this key off.
There are a few diodes in the circuits which could draw a few miliamperes in reverse bias.
