Boatcarpenter
- 17
- 0
- Marlborough, NH
Sunday, while on a short drive to get the truck up to temp to circulate water as part of a system flush, I lost all electrical power with a pop from the battery area. Assumed it was the main battery ground so cleaned it all up and put it back together. I have power at the slave cable socket, the two # 11 wires at the main switch, continuity through the switch. I also have power into and out of the horn breaker. But, turning on the switch excites nothing. No heater, no horn solenoid, no lights, no starter button action, no nuthin!!!! Have I lost all grounding between the whole dash panel and the rest of the truck? If I have, is there a dedicated ground strap for grounding or is it just through the bolts?
Any ideas appreciated.
Thanks,
BC
Thanks,
BC
